Spotlight accessories
i did something to my settings in Spotlight accessories,now i can’t change from sunset to sunrise back to motion or sound detection?,
i have 2 spotlights cams and suddenly i can’t turn on one of the lights from the app manually?
[Mod Note]: Your duplicate topic has been merged to conform to the Community Guidelines. Please avoid crossposting the same question in multiple topics.
i have 2 spotlight v3 cams and now i can’t manually turn on the lamp on one of them from my app?
Is the light burned out maybe or does it work on auto?
If you were upgraded to the 3.0 app, it seems many bugs/glitches can be resolved by uninstalling and reinstalling the app fresh. If that doesn’t do it, try deleting the cam and re-adding it (assuming it is accessible).
NOTE - do not uninstall the app if you are still on the 2.X version. That likely means your device is not compatible with 3.x and you can no longer do a new install of 2.X!!
Unplug the camera and unplug the spotlight from the camera. Plug them all back in and see if they fixes things. I have one V3 camera with the spotlight attached to it and have never had this issue…yet.
