Anyone suggest using wyze cams to estimate driver speeds?
Live in a residential neighborhood with neighbors speeding by. Would love the feature to estimate does
Don’t think it would work. My cams record 20fps during the day and 15 fps at night. Sometimes the cloud event playback shows the vehicle moving slower than actual speed and sometimes faster. The recordings on the SD card are a little better but not much. Forget about getting plate numbers on a moving car especially at night.
My dash cam recording 2K at 60 fps would work a lot better. ![]()
Yeah as @antonius mentions, the FPS is way too low to do any sort of accurate calculation. There are cameras specifically made for doing that, they typically use radar and feed the data as an overlay on the video, and these days can probably capture the plate automatically too. If you run an HOA or something then may want to consider investing in something like that.
Just "borrow"a Flock Cam.
Yeah, actually I talked to people that do this. But, spoiler: as they said above, Wyze FPS is basically the bare minimum for slower residential roads.
Basically you activate the “RTSP” feature in advanced settings.
Then you install an opensource program (or there are proprietary software versions instead of you want to pay money) that is actually designed to convert camera recordings into speed and other fancy things.
Look up things like:
Speed calculation depends on
• Practical Minimum: 15–20 FPS (Residential/Low-Speed, < 30 mph). Below 15 FPS, a fast-moving vehicle skips too many pixels between frames, causing tracking algorithms to lose the vehicle ID or drop tracks.
• Recommended: 25–30 FPS (Highway/Standard Roads, ≥ 45 mph / 70 km/h). A car moving at 60 mph covers ~88 feet per second. At 30 FPS, the car travels ~2.9 feet per frame, providing enough data points to compute reliable displacement averages.
The Wyze V3 cam does 20 FPS in normal daylight mode (don’t use nightvision), so you are pushing it at the practical minimum for 30mph residential areas, and presumably you want to track who is going FASTER than 30MPH, so the Wyze cam FPS is probably not suited for your purposes. Basically it can tell you they are going “too fast” to accurately detect their speed, but it won’t give you accurate speeds for the speeders because the FPS is too low.
But honestly, I’m not convinced how reliable it is. In my experience it seems that Wyze uses a VFR (Variable Frame Rate) which is not ideal for this purpose.
BUT there are some other really cool programs to track traffic and hotspot zones and times and all sorts of things.
But the short answer is YES, it is possible for you to do it…but it’s pushing the limit at 20FPS.
