Some steep discounts for Wyze home monitoring starter kit at some Home Depots
The starter kit is showing as $49.98 at the Bellingham Home Depot. Maybe it’s a sign as I’m down to my last working V1 motion sensor. Time to retire the OG Sense bridge.
WOW! That is a great deal! I just checked my local THD and it’s still $99.98 near me. I was totally going to buy another one of these if it was half price here too. I kind of want a second hub, another Keypad, and I can always use more sensors.
FYI, the V1 motion sensors also work really well on the new hub. Better, even. The signal/reception is better and more stable.
I thought you were in Canada. If so, I guess you are close to the border then?
Yup! super close to the border I have a PO box on the state side and cross weekly. I’ll try to keep the last motion sensor alive since I have a ton of batteries left over :sweat_smile:.
Grab it while you can! My store is still @ $99.98 too.
Looks like it could be a Washington thing. Found a few cities in WA with the same price. Neighboring states show $99.
This is blatant favoritism I tell you…just because Washington is where Wyze Headquarters are. They should give my state the same deal so I can buy an extra set! :joy:
Road trip! :blue_car:
