Internet has excellent strength and reception. It’s been deleted, restarted, no rules or shortcuts on it. I have 2 (1 is pan, 1 is regular) other cameras that work great.
They have 32gb cards in them.
Ideas?
i have same issue with my v2 i just set up. i can view live feed but wont record any video local or to the cloud. i just formated the wyze sd card. i bought with the camer and have all alerts set to on except for noise detection. i did set up a iftt trigger to upload a video to the loud every hr and that video said it was being uploaded still or didnt exsist. i did update the firmware and set it up for the first time today
I have the same issue. My pan and scan works just fine, but the V2 I just set up is not recording anything. Firmware is up to date, I can watch live, but it does not record any event or show any playback either.
Help!?
so far it looks like new activated cams are having this issue my other wyze cams i have work fine just the new one i activated today
I have the same problem. I have gone through all the troubleshooting possible (with the support staff) and I still can’t get my brand new cameras to record any events or send notifications. I am getting really frustrated. Wyze support is saying that I should try “flashing the firmware”. But even they are not sure if this will work. I can watch live but that is all.
factory reset did not fix my issue on this
factory reset did nothing to help I havent Flashed the firmware yet. anoying only new activated cams this issue
Flashing the firmware worked for me. Make sure to follow the steps closely for this process.
thanks thats the thing i didnt do yet.
i did the firmware flash and worked for me as well
