Solar Pan Cam solar panel cable
Is there a recommended length for the cable running to the solar panel? I need about 15 - 20 feet
thank you in advance :slight_smile:
@brian.mackey If Wyze doesn’t list a maximum in the panel’s specs, it’s worth asking support whether they offer an official extension for it. The catch with longer runs is that a solar panel puts out low voltage, so a long or thin extension loses some of it before it reaches the camera and can slow charging. If you do go 15 to 20 feet, I’d pick the thickest weatherproof cable you can find with the right plug, seal the joint against rain, and then compare the battery percentage morning and evening on a sunny day to confirm it still charges like it did on the stock cable. How long is the cable that came with your panel?
The official spec for USB is 15 feet. A good thick cable might let you go further, but as the other comment mentioned, the longer you go, the more voltage drop you’ll have.
The 10-foot standard cable I need about 8 feet more
Unfortunately the only way to know is to try. Multiple connectors (each adding a bit of resistance) and longer than spec may work with little to no impact, may cause weird glitches, or could even reduce the lifespan of the camera by giving it too little voltage. The best thing would be to try and get a 6 meter cable that can connect directly from the panel to the camera, rather than an extension, and pick the heaviest gauge one you can get (preferably round, not flat). However I’m not sure if the cable can be removed from the panel, in which case you’re stuck with a 2 or 3 meter (or 10 foot) extension as the only option.
If you’re running a wire that far, have you considered running an ethernet cable and using a PoE injector and adapter with a standard wired cam? Can go very long distances without voltage issues. Plus you aren’t crippled by the limitations of a battery camera.
Okay, I’ll find an outdoor 5-foot extension, hopefully it will reach :slight_smile: I have lots of bright open sky, but it won’t charge
Honestly the 3 foot difference probably is less important than heavy gauge cable and less connectors, but not sure if that’s an option with that particular solar panel.
There are cheap inline USB power meters you can get off amazon, which would allow you to see how much voltage the cam is getting when the sun is hitting the panel. I wouldn’t want to be below 4.8 volts minimum where it connects to the cam. Or like I said, you can just try and see, but long term issues may not crop up at first.
