Solar Pan cam 2K
I’m on the basic sub and I read that events are supposed to record at least 12 seconds to sdcard but am barely getting 5 or 6 seconds.
I have 3 of these and all same story.
Anyone else having similar issues?
What am I missing?
SD card records 1 minute minimum (unless they did something different due to it being a battery cam, but even then it should record for as long as there is motion). Are you sure you’re viewing the SD card recording and not the cloud event? There are many things that can interfere with cloud video upload, but SD card, assuming the card is good, should be consistent.
I choose the event and then I press “sdcard”…it plays a few seconds and stops.
That’s not the cloud right?
Sounds like there is some sort of playback issue going on, does the cam have a good wifi signal, and does the card report the correct capacity when you view the SD card settings? What kind of card is it and where did you get it from - there have been a lot of issues with counterfeit cards lately.
Have Kingston and Sandisk cards that were previously in regular Pan cams v3 and working flawlessly for years.
Will swap some sdcards around and see if it gets better.
Thx for reply
It probably isn’t the cards then, I’d potentially focus on connectivity. Maybe try setting it to continuous recording for like 30 minutes or whatever, then go play back and see if you have any similar issues. If it records fine but won’t play back, that’s pointing to connectivity or possibly an issue with the app/your device.
