Dissatisfied - Solar Cam Pan will not record vehicles or pets. Fully charged. Detection Zone on. Detection Range on far. Motion Sensitivity on high. Event motion recording is set to all events with all customized detections on. Has a Wyze MicroSD card set to record events only. The pan controls are calibrated with the proper angle and the motion tracking is on. But still won’t record vehicles & pets. Only records people within 20 feet. Does anyone else have this problem?
Is it consistently recording people within 20 feet or only sporadically? There are two things that come to mind - smart detections (recognizing people and cars etc) requires a good wifi signal and internet connection since that processing is done in the cloud, and those detections only work at certain distances, preferably at a fairly flat angle. What kind of distances are the vehicles at that aren’t being detected? Maybe post a screen shot of the field of view?
One more thing to check: battery and solar cams like this usually wake up from a PIR heat sensor rather than watching the video nonstop, so if a car or pet never trips that sensor, the camera never starts recording for the AI to classify it. PIR range is limited and works best when things move across the view rather than straight toward it, which would fit people only getting caught within about 20 feet. It is also worth confirming your plan includes vehicle and pet detection, since on some plans only person detection is included.
