Smart home
Is there a way to connect my cameras to my tvs? I have Android phones, a Roku TV and 2 smart tvs. If not then I will have to buy future cameras elsewhere. Thanks for any help or advice
Short answer is that it depends on the TV platform. Wyze has no Roku app that I know of, so on the Roku I’d expect the least luck. If either of your smart TVs runs Google TV or Android TV, or you have a Chromecast or Fire TV stick, you can cast the live view from the Wyze app on your Android phone, or use the Alexa or Google Home integration to say show the front door camera on the TV. Check which voice assistant and TV brands you have before buying more cameras, because that decides how easy it is. Newer Wyze cams like the Pan v4 can also turn on RTSP, which lets any player that handles RTSP show the feed, though that takes some setup and I’m not sure which Roku channels support it.
You can connect them to Alexa (I think google home too but not sure). My fire TV stick can view 1 cam at a time by just saying “show me [name of cam]”
Tiny Cam is another option you can look at, not sure what platforms that supports.
Welcome to the Forum, @needstoknown512! :wave:
More detail about the TVs would be necessary to provide a better answer to this question, but I’m able to integrate my Wyze Cams into Google Home and watch feeds on a television running Google TV as well as via a Google Chromecast HD connected to an HDMI port on a non-Android smart TV. I’ve also been able to view Cams through a Roku Express using Screen Cast from a mobile device. You can search the Forum for additional solutions other users have found for viewing on TVs.
