For the last week my pan reacts fast but there is a 20-30 second delay before it shows action on my phone…I have rebooted both and my wifi over and over…Please help…Oh what is android 387 and x75?
Update. Now it shows live slow motion on phone…No sd card or recording…This cam has been a problem for awhile now.
There have been some problems with the new app update , if you would like , you can rollback to the previous app version .
If you decide to do so , download the file , uninstall your current app and then install previous version.
You can find the file for V2.4.82 here
https://support.wyzecam.com/hc/en-us/articles/360009818512-Android-Wyze-App
Also , if you can’t get the help you need here on the forum and the problems persist, you can contact support about this issue and submit a request.
