No, but a search of Wishlist and #roadmap yielded this:
Thanks, what about, having the same camera in multiple groups?
All my three cameras are now working perfectly with TinyCam android and access via web server. One thing to note is that the Web server feature only available on the PRO version (not on the FREE version)
Thanks for the wonderful instructions.
Can i use the beta version for viewing multiple cameras on my samsung tablet or is the beta version only available on certain platforms?
There is no need for beta To get this function .
The Wyze Public app Android V2.2.38 Is already capable Of viewing multiple cameras, You just need to set up groups for your cameras.
As long as you have Android version 5 Or higher on your tablet the beta or public app will work
https://support.wyzecam.com/hc/en-us/articles/360022543292-Wyze-Cam-User-s-Guide
Thanks @HDRock
Feet, cameras are outside. Though it seems after switching everything over to the comcast router and tweaking a few settings everything is working fine now. I can stream my 3 cams on my phone without issue most of the time. 1 cam will occasionally drop out but it reconnects fast.
I do see my multiple cameras now (says updated to the latest version on my samsung tablet) but its not showing live view when I am viewing the multiple cameras. I have to click on 1 individual camera to be able to watch the live feed from each camera.
Could you clarify pls, does the beta version of wyze that others referenced above allow viewing live stream from multiple cameras simultaneously or is tinycam the only option to be able to facilitate that?
Is it normal to experience a 20 second delay between something appearing in the field of the camera and me seeing it on the app? Ie. A car pulled up on to our driveway and i timed and noticed a 20 second delay between when the car actually pulled into the drive way and when i saw the car appear on the stream i was watching from wyze app on my tablet. Is that amount of delay unusual?
Do you have Hardware Decoder (Account–>App settings–>Camera) turned on?
https://support.wyzecam.com/hc/en-us/articles/360022543292&?section=hardware-decoder
I look at Live views With multiple Cameras everyday , one group has 4 cameras in it .
I’m using the public on 2 devices
I can even view 3 cameras that are shared with me All at once In multiview .
Could be you have a Wi-Fi problem
I get a lot of lag on my older Samsung tablet , it’s kinda pokey About everything , But I can still view A group of cameras on it.
I never timed it but It’s probably about 20 seconds
I don’t get lag on my Samsung s9 +
Thanks @gemniii. Your suggestion seems to have worked
Hmmm if I can watch live view adequately for 1 camera at a time, it doesn’t sound like the issue is my wifi. What are these “groups” that your referring to? I just opened my wyze app and added each of my 2 wyze cams individually. I did not do anything with “groups”. Could this be preventing me from watching live view on multiple cameras simultaneously
Check out ‘groups’ in the following article:
It’s not safe to give your Wyze account credentials to Android/Android App. Wouldn’t recommend it at all.
Could really use this with a laptop / Tablet for 4 cameras but happy with the streaming view alerts so far.
I get multi view on my tablet
You can do this by using grouping in the Wyze app.
https://support.wyzecam.com/hc/en-us/articles/360022543292&?section=grouping
