Simple 3D Printable light shroud for Video Doorbell v2
I designed a simple light shroud to use with a Wyze Video Doorbell v2.
This is to help block light from overhead porch lights from causing lens flare artifacts. It is simple and easy to print. I use double sided Scotch tape to fix it to the top of the camera without being permanent or requiring a full wrap around design. The petal design of the lens hood is to minimize the amount of the image that is clipped. I needed a little bit of the corners to still be blocked because that is where my lights were. But it is very minimal and should work well for many use cases.
https://makerworld.com/en/models/2672579-wyze-video-doorbell-v2-light-shroud#profileId-2958386
Nice! Im not sure I need it but I do have a new 3d printer. Do I’ll give it a go.
