My cameras are located very close to power outlets. I can’t find short cords with the right profile to fit the camera. Any suggestions?
How short do you need?
Heres some 1 ft. ones.
!ft USB B
I bought these 6" cables, they work fine:
This is what I bought, but the profile of the connector is to large to fit into the slot on the camera. Could Wyze sell shorter cords?
Thanks! I’ll order these.
Take a razor or knife or dremel and just shave down some of the plastic. Should fit just fine then. Thats what I would do. Its a simple cord. I havent had any issues with any of them honestly.
