I’m experiencing severe battery drain when viewing a live stream , the phone instantly starts getting warm.
Remdies i have tried , deleting and re installing , latest app updates, beta version
This problem is specific to the Wyze app using way too much phone resources , I regularly conduct Zoom and Microsoft Networks video calls.
No significant battery drain or the phone heating up
I tried to duplicate your issue on my iPhone 7+, my iPad and on my wife’s XS. All are just updated to the recent 13.xx IOS. I didn’t experience any heating or noticeably rapid battery drain. Tried both in group cam view and single cam mode.
Have you checked your Settings/Battery to see if your brightness settings are high or if your device is set for low power mode or not? You can also check to see which apps are using the most battery power. Mine is usually the Wyze app but it’s not causing the issue you describe.
