I have had several SD card problems using different SD cards: Failure to recognize, incorrect capacity, failure to record events.
One of the Wyze staff mentioned formatting with exFAT32.
I have formatted all of my cards with exFAT32 instead of FAT32
The odd SD problems have disappeared.
All of my cameras are V2 purchased directly from WYZE in 2018
I use 32 GB sched 10, SanDisk, Micro SDXC, Samsung EVO Select
Why use exFAT:
“exFAT is optimized for flash drives—designed to be a lightweight file system like FAT32, but without the extra features and overhead of NTFS and without the limitations of FAT32. exFAT has very large limits on file and partition sizes., allowing you to store files much larger than the 4 GB allowed by FAT32.
Difference between FAT32, exFAT, and NTFS File System …
https://www.geeksforgeeks.org › difference-fat32-exfat-ntfs-file-system”
