Need To Be Able To Disable Camera Notifications Separately From HMS Notification.
(If Disabling WYZE Cam Notifications, HMS Notifications Should Not Be Disabled Also.
There Should Be A Separate Switch In The Monitoring Tab Or The App Should Ask Which Notifications You Would Like To Disable).
How about Option to stop HMS notifications if system disarmed
