Separate cams
So, I have several Wyze cams in my home, work great. I’d like to add several more cams at my work. I would like my employees to have access to the work cams, but not the home cams. With just one Wyze app on my android phone, how do I do this?
Each of them would need to create their own Wyze account then you can share the devices with them. Sharing is per device right now so as long as you do not share your home cameras with your employees they will only see the work ones.
A limitation of shared cameras is you don’t have much control over the cameras. Shared users can change settings and turn cameras on/off.
A common problem is a shared user turning off notifications for everyone thinking it only effects them.
Thanks!
