Sense V2 Motion Sensor false alerts
I have 2 Wyze Sense V2 motion sensors connect to my Home Monitoring system. The one that came with the Code Started Kit works just fine. But the add on sensor I purchased separately gives false motion alerts every 13 seconds like clockwork.
I deleted the sensor, and then re-added with no luck. Same issue. I moved it to 3 different locations away from all other sensors, same issue. I took it down and placed it in a drawer by itself, same issue.
I have submitted logs to Wyze but not a peep from them. I know someone else on here had the same issue, just wondering if they ever had any luck solving the issue.
Have you tried removing the batteries and replacing them, possibly with new ones?
Quick update…
After speaking with support, who I will add was fantastic, I finally figured out what was causing the issue with the Wyze Sense v2 motion sensor giving false alerts.
I deleted and re-added the sensor, which I had done 2 or 3 times before, but this time, I added it within the Home Monitoring tab, in the Home/Away section, instead of from the main “Home page” of the app. The sensor now seems to be working as it should.
Hope this helps others having the same issue.
Having same issues thanks for update!!!
I just wanted to confirm that this does work. In January I received a replacement motion sensor for one that was always showing low battery. The first night with the new motion sensor caused two back to back calls from Noonlight for false alarms. I disabled that sensor.
The replacement for the replacement was exhibiting the same false alarm behavior. Even in a drawer with no motion possible, it was detecting motion.
I’ve now got all three sensors (original, replacement 1 and replacement 2) added via the HMS screen and they’re all behaving very well. No false alarms in the last 48 hours.
I don’t know why this works, but it seems to be the solution.
Still working great
