When i view playback from the sd card, it works for a while but then the camera goes offline. Its takes about 10 minutes for it to come back online. During the time it is offline, the led is flashing blue-yellow. Any ideas?
[Mod Edit]Title changed to reflect correct device.
Here is what the red/blue status lights on the v3 indicate,
How are you powering the camera? What size power brick and cable type? Are you using the supplied power brick and cord? Or are you using your own USB cable?
