@jthoclc… thanks so much. I’ll attempt to have someone get in touch with you privately.
Ok, update.
- 15 all new 32 GB cards. Sandisk from Amazon.
- Formatted all with WyzeCam App. All showed 29.17 of 29.17.
- Motion bars show on playback screen for all cards.
- 8 of the cams will show playback when index bar moved over the motion bars.
- 7 of the cams show “operation failed” when the index bar is moved to the motion bars.
- Re-formatted those 7 cards. All cards showed some use before formatting, and showed a return to 29.17/29.17.
- These are random V2 cams at various locations-no distance from the modem correlation.
- 12 second events record and show normally on all cams.
Are those cards working again after being reformatted?
They are not working after re-formatting.
Too bad
Update:
Like many, I also had the problem of no,access to cams remotely. After I performed that firmware update, not only did it cure the access issue, but it also cleared up my inability to do playback of motion events discussed above ! Don’t know why, but am very happy with the results !
Thank you for letting us know! @Loki told me you’re willing to send us the bad SD cards. We’d like to replace some of your bad SD cards with Wyze SD cards. @MarsLikeThePlanet Could you help bringing back 3 of the bad SD cards please?
Will be happy to send you all 10 of them ! Can you please give me a mailing address ?
I sent you a PM ![]()
