Do I need an sd card in both the Wyze outdoor cam and the base station? Need help understanding. Thank you.
From what I am seeing with limited testing on my Outdoor Cam, you only need one in the camera to record.
The Base Unit appears to only be a backup for the camera(s) that are connected to it. The camera has an option to ’ Backup to Base’ that you can turn on/off, assuming you did have a micro sdcard in the base unit.
I have found no way to record to the base unit with a micro sdcard if you don’t have a micro sdcard in the camera.
