SD card causing Wyze Cam Pan to constantly restart
Hello!
I have had a Wyze Cam Pan for a couple months. A couple weeks ago I added an SD card. Yesterday the camera started acting like it was constantly restarting every two or three minutes. It was working like normal in between restarts. I removed the SD card and reset the settings and reprogrammed. It was working fine after that, then I put the SD card back in, and it started restarting itself again. Removed the SD card and the restarting has stopped.
Could the SD card be bad, or could it be a problem with the camera?
Firmware version: 4.10.1.8
Could be either. Did you reformat the SD card?
Yep, that was it. Thanks! I should have thought of that.
I first tried formatting the card in the camera. After a minute it made a “boing” sound and the light turned orange. I restarted and the card was still showing full, so I hit reformat again. This time it said it failed and the cam didn’t see the card at all. So I plugged the card into my laptop and formatted it there. Now it’s back to normal in the camera.
Thanks again!
You’re welcome. Glad that fixed it.
