Scale only shows weight. No other measurements. Notified Wyze. Received amazing reply that scale only works as advertised for people between ages of 18-65!!! Suggested solution was change my age. Seriously. I don’t recall seeing age limits in any of the scale ads before I purchased it.
This took me a while and some experimentation. I’m 81 and definitely in the athlete group. I finally worked through all the other possibilities to arrive at the <66 requirement. I did get alerts when >65 that said some things won’t/might not work. Since then I have seen reference to the <66 requirement. I’m OK with using <66 and now I’m getting all the info. I’ll see if it is accurate as I can compare it to a number of other sources. So far it looks like weight BMI and heart rate are very accurate ( a few measurements ).
