I'm lying to the Wyze scale
After months of not using the Wyze Scale for anything except to get my weight I found some documentation on some of the finer points of what the scale will do and how to set it up.
Did you know that if you are 80 or older and put your age in the app you only get your weight?
So, I lied. I am now 75 in Wyze age.
And, never set the “Athlete” mode to Yes unless you are basically an Olympian. You RP has to be 60 or less.
