I’m trying to stream a V2 cam on YouTube using the RTSP firmware. The audio is useless - just a few pops and crackles. Video quality is super compressed, too. Anybody know of a solution?
Thanks
Tim
Thanks
Tim
I use one cam on RTSP just for local viewing, but another user on another forum posted that they had use the just released firmware for converting/dedicating a cam to being a webcam and made it work.
I’ve used the firmware and it works great but I haven’t tried it on Youtube yet. Just FYI.
Caveat:the cam once converted can’t be used via the Wyze app unless you reinstall the standard firmware (which is easy to do)
New RTSP firmware?? I’m going looking now! Wyze, please post a link in case I can’t find it. Thanks for the tip Tomp!
I have 4.28.4.41 installed. Is there a newer version?
I don’t know if this applies to your use case, but you could try the webcam firmware Wyze recently offered. Also, you appear to already have the latest RTSP firmware.
