Anyone have issues with the roller brush cycling on and off while vacuuming carpet? Mine just started doing this on (low and higher pile) carpet. Is this normal or am I just noticing this for the first time? Is my vacuum defective?
Mine also does this. 1-2 seconds running the brush, then brush stops… rinse/repeat. Didn’t do it in hard surfaces. I know it’s the main brush that’s stopping because I slightly raised up the vacuum while it was running around and could see it stopping and restarting. Relatively low pile carpet (read: not super expensive)
I should note that it did this straight out of the box. Bearing is in place, clean and rotates freely.
