Reset data info in the wyze scale
When I initially got the scale I was playing around with it to try to figure it out and THAT data got stored and I need to clear it and start fresh. It has my weight 30 lbs higher than it should be and other info that’s not accurate. How to I get a clean start?
You need to adjust YOUR weight. Trust in the Wyze.
So you don’t have a solution to my question??
You’ve tried the FAQ, yes?
https://support.wyze.com/hc/en-us/sections/360011231752-Wyze-Scale
Similar problem with the Band. If you time an e event, it can not be deleted or even modified.
Ok, on the App click on Trend.
Click the 3 bars top right
Select a day
Click the Trash icon top right
I went to scale s in the app and at the bottom of the info page it has a ‘delete’ I clicked on it and had to reinstall the device in the app. You start over at that point.
I have a different model, but it says to
Hold reset button inside battery box.
Does a total reset.
