Required power in watt for WYZE Cam Floodlight Pro?
Hello
What is the power in watt required for the WYZE Cam Floodlight Pro to consider it for selecting 220v to 110v voltage converter?
As i know old version WYZE Cam Floodlight has 48W but not sure about new Pro version.
BR
Tech Specs say "about 46W.
Same situation here. I have the Pro camera with the hardwire connection (no US plug) and trying to figure what to do next. Need to ensure the converter/transformer is waterproof for outdoor use of the floodlight. Did you find the hardware needed? Thank you.
