Power requirement for Wyze Cam Floodlight
Would like to run the Wyze Cam Floodlight with the Wyze Cam v.3 off solar. What are the power requirements for doing so? I was able to find the power requirement for the V.3 but nothing
for the floodlight/sensor
Welcome to the community @Rockyptjoe
The flood light is 110V~120V. Knowing what the Wyze Solar Panel is like, I don’t believe there would be enough power for the Light and Cams,
Were you planning on using the Wyze Solar Panel?
Starting point is finding out what it draws. Next would be to get the output of the wyze panel. One step at a time
