I wasn’t sure this was going to be a permanent place for this camera so, I didn’t want to use sticky Stuff or Screws .
Originally I thought I was going to hang it from The Top door molding but,Decided to make it to Stick in Between the quarter round and ceiling .
To my surprise The magnet actually helps hold The hook that’s bent into the end of the wire .
Started out with 13 inches of hanger wire ,Bent it to shape, the hook across the bottom Is 3/4" wide, to fit In the bottom Mount deal
You might think it might fall off but It will not , It’s Not going anywhere in less there’s an earthquake .
You could probably use this in different places, bend the wire how ya need it.
Pictures didn’t go where it wanted to on the page but , oh well !
