I agree this this is likely going to come down to some simple change needed to everything working.
Do you happen to have a guest wifi network set up on your Arris modem? Have you made sure that the amcrest, foscam and wyzecams are all connected to the same SSID (i.e. none should be on your guest network).
What are the ip addresses of the three cameras in question? Do they look like they’re all on the same subnet? (i.e. are first 3 numbers in the addresses the same for all of them)?
What model of Arris do you have? I have access to an NVG589 and a BGW210 in case you have one of those. You can check your model number by clicking “more info” on the status screen of the modem.
Both of the two modems I checked have a “device list” tab next to the main status tab. It might shed some light on what’s going on if you can share the entries that correspond to your three cameras.
Yes, you would lose RTSP capability. If you flash it manually, I would make sure the RTSP firmware bin file is not on the SD card, just delete it and replace it with the standard .60 bin file and flash.
Just putting my two cents in here - 1 Wyze Cam v2 on a 2.4Ghz WAP, 15 feet from the WAP. There is 1 other camera on this WAP, a cheap 720p camera. All motion detection off on the wyze camera (no cloud recording, no local recording). I’m using beta 2 RTSP firmware, I get common dropouts at random and immediate dropouts 1-2 seconds into motion. WiFi signal is 80%. Beta 1 firmware did not dropout, however the framerate was between 1-5 fps consistently. I do not get dropouts on the 720p camera.
Happened again. Made it about a week, went to check on the camera feeds and they’re all offline (including the app). Not sure what would be causing this?
All the cameras are on the same network SSID (VirusLoader2.4).
Oddly enough, although the Foscam works through the app (and through tinyCam) the MAC address that the Foscam app shows doesn’t match anything in the router device list. (??) Zoneminder shows it as being on 192.168.254.62 (where it was working until I plugged the PC into the router by wire).
Here are the network IDs of the 2 Wyze cams, plus the Amcrest.
Hmmm … well, it sure does look like all the cameras are in the same subnet and on the same SSID, which makes this pretty weird.
What is that screenshot from? (Is that your Arris modem? I’m surprised that - from the images in the list - it looks like the software knows that the ips are cameras. My Arris modems have no images but they also show a bit more information than what’s in your list.)
Also, what’s the IP address of your PC, when it’s on the wired network, and when it’s on wireless?
When the PC is on the wired network, is it plugged directly into your Arris modem, or is there anything else between the PC and the modem?
Yes, it’s from the main screen of the Arris router. It’s not automatically recognizing the devices; the Arris interface lets you assign an icon to each item in the list.
The Arris interface reports the PC running Zoneminder is on 192.168.254.10, port 4.
The PC running ZM is plugged directly into the router/modem.
Okay, so right now with the PC on the wired network, it’s the amcrest that is not accessible, right?
On the PC running zoneminder, what do you get if you run
arp 192.168.254.42
(That’s the IP address of the amcrest from your screenshot. Substitute the correct IP address if it has changed. Ideally, you should see the mac address of the amcrest when you do this.)
Also, what do you get if you run
route -n
Lastly, when you ping and/or try to use telnet to port 554 on the ip address of the amcrest, what exactly happens? (i.e. no response at all, or do you see any kind of error message?)
(Sorry for the back and forth. This is turning out to be puzzling, although I still think it’s likely to be a slight misconfiguration somewhere.)
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.254.254 0.0.0.0 UG 100 0 0 enp0s25
0.0.0.0 192.168.254.254 0.0.0.0 UG 600 0 0 wlp1s0
169.254.0.0 0.0.0.0 255.255.0.0 U 1000 0 0 wlp1s0
192.168.254.0 0.0.0.0 255.255.255.0 U 100 0 0 enp0s25
192.168.254.0 0.0.0.0 255.255.255.0 U 600 0 0 wlp1s0
When I telnet to the Amcrest, this is what I get:
telnet 192.168.254.53.42 554
telnet: could not resolve 192.168.254.53.42/554: Name or service not known
(Again, this is with the cable plugged in, I can try it after unplugging the ethernet cable if you want to try that.)
No trouble at all for the back and forth, I’m grateful for the help from someone that knows alot more about this than I, and who knows what to look for.
Let’s focus on the wired network for now, and if we don’t get anywhere we can try the other way around.
One interesting thing that I see from your ifconfig output is that your PC is still connected to your wireless, but the routes are set up so that it will always prefer to send traffic on the wired network while the wired network is connected. From the arp output, the amcrest mac was visible only via wireless and not via the wired network … That doesn’t say exactly why the amcrest isn’t reachable but I’m wondering why it even tried the wired network – and perhaps the root of the problem is that it thinks your amcrest might be reachable directly via the wired network without going through the gateway. (I’m not sure, but less try to narrow it down.)
It would be nice to debug this without having 2 network interfaces active at the same time. Is it possible for you to turn off the wireless on your PC and then send the outputs again for:
route -n
arp 192.168.254.42
arp 192.168.254.53
telnet 192.168.254.42 554
(Btw, you mistyped the telnet command ip address in the last round of output.)
Shutting down the wireless on your PC will allow us to see if any of the wifi cameras can actually be accessed from the wired network.
If it’s not possible to turn off wireless on your PC, then unplug the wired network from the PC, and run the above commands, and we’ll try to figure out why the wyze cams aren’t reachable but the amcrest is.
Lastly – Is your Amcrest camera only connected to wireless, or does it happen to also be plugged into the wired network?
Okay…here we go.
I unplugged the network cable, and the other cameras came back online, including the Wyze camera that has the RTSP firmware. (errr, whut?)
Anyway, here’s the output of those commands:
arp 192.168.254.42
Address HWtype HWaddress Flags Mask Iface
AmcrestCam1.frontierloc ether 3c:ef:8c:aa:1c:48 C wlp1s0
secuser@secuser-control:/$ arp 192.168.254.53
WyzeCam1-192.168.254.53 ether 2c:aa:8e:11:fe:1f C
Trying 192.168.254.42...
Connected to 192.168.254.42.
Escape character is '^]'.
Connection closed by foreign host
Soooooo, maybe all I need to do is flash the second Wyze camera with the new FW. I’m confoozed. I could have sworn it was not working, which is why I came here in the first place. Maybe I have a head injury.
Now that you’ve disconnected the wired network, there is no ambiguity in your routing table as far as how to reach the cameras. (Notice that there’s only one entry for 192.168.254.0, whereas there were two previously.) I don’t know exactly what happened, but assuming you weren’t just imagining it, I think something on the PC was confused about which network interface to use to try to contact your cameras.
Anyway, if it happens again, please rerun those commands with the PC connected to just one network and we can look at it again
Hi there. Sorry about the wait. If you insert a SD card to the camera and hear the “Ding-Ding” sound, there would be a device log created on the SD Card.
We have problems with continuous record if the cam doesn’t have internet connection. It stops recording after 2-2.5 hrs. You said a couple hours, would that be 2-2.5 hrs. You mention connection to the internet, your cams have access to WiFi but not the internet, is that what you are saying? The continuous recording problem I assumed was due to loss of WiFi but I’m thinking it’s actually due to loss of internet now if yours problem has WiFi still.
Check to see if you select RDP/UDP (or RDP/Unicast) on your Remote Method selection and use that. Note that my cams do not have access to the internet (have two network cards in same computer, with different IP addresses and cam network card has no gateway).
Had the same problem on Blue Iris until I selected RDP/UDP and assigned a different port to the two I have (7100, 7200) and it’s been running 24/7 for several days (using the first V2 beta version). Note however, if I make a change via BI dialog for the camera, it looses the signal and I have to unplug/plug the AC on the cam.
Is UDP better for RTSP? I have a lot more visual artifacts appearing in my videos when I use UDP over TCP. If I was multicasting I get the benefit of UDP, but unicasting the overhead seems minimal and the quality appears much better (in my case anyway, I cant go more than about 10 seconds of video before compression error type pixellation / bleeding occurs).
TCP has a lot of overhead with a three-way handshake setup and teardown. UDP has no acknowledgment of data packets received and will drop packets received out of order, etc. TCP for live Video and VoIP can suffer from high latency and be choppy as it will wait for a missing or late packet. This can lead to more issues with the extra overhead in bandwidth use than the occasional dropped packets of UDP. TCP is good for routing and control like PTZ where you need confirmation of an action.
What RTSP does by specification is a combination of both.
RFC 2326
Reliability and Acknowledgements
Requests are acknowledged by the receiver unless they are sent to a multicast group. If there is no acknowledgement, the sender may resend the same message after a timeout of one round-trip time (RTT).
The round-trip time is estimated as in TCP (RFC 1123) [18], with an initial round-trip value of 500 ms. An implementation MAY cache the last RTT measurement as the initial value for future connections.
If a reliable transport protocol is used to carry RTSP, requests MUST NOT be retransmitted; the RTSP application MUST instead rely on the underlying transport to provide reliability.
If both the underlying reliable transport such as TCP and the RTSP application retransmit requests, it is possible that each packet loss results in two retransmissions. The receiver cannot typically take advantage of the application-layer retransmission since the transport stack will not deliver the application-layer retransmission before the first attempt has reached the receiver.
If the packet loss is caused by congestion, multiple retransmissions at different layers will exacerbate the congestion.
