Could someone please tell me if I can record continuously without paying for Cam Plus if I put a 32 gig SD card in each camera? I understand that it will only save 12 seconds to the cloud, but can it record and store continuously to the SD card without Cam Plus?
I haven’t purchased the system yet, but it sounds fantastic from what I’m learning. I want to go ahead and purchase ASAP!
Complete system with window and door sensors on every window and door and motion sensor in every room and water sensor under every sink and behind every toilet and by the water heater. I will also buy V3 cameras and put them indoors pointing out windows (possibly even put one in every window, but probably not, but definitely at least 6 of them.)
The only problem (and it’s a big one,) is that there aren’t any smoke detectors.
Other than that $60 / year for monitoring is AMAZING! The cheapest I could find is $15 per month which is $180/year… and $25/month which is $300 per year if you have cameras.
