Questions on new Wyze bulb cameras
I have two of the Wyze bulbs with cameras coming via Amazon. I just have a few questions.
What is the temp range on these? Winter can get down to -15, so I was wondering if they would not work during extreme cold?
I want to put them in recessed pot lights. One outside on my porch, and one in my living room inside. I am wondering how the light/camera combo works if the light switch for the pot light is off? Will the light go on and off with the switch, but the camera is always on?
Thanks
Check out the product page, which says this in the “Tech specs” section:
Operating Temperature: -4°F - 122°F (-20°C - 50°C)
No, if you turn off power to the light socket, then the camera—which is powered by the socket—also turns off. For something like this, whenever you want the camera to be on you’ll want the switch controlling the circuit for the light socket where Bulb Cam is installed to be on. Switch guards are useful in this situation to minimize accidentally turning off power to the camera. The lighting is controlled within the Wyze app.
Welcome to the Forum, @kathi.schwan! :wave:
