On iOS go to settings on the phone, scroll down to the WYZE app and tap the arrow on the right. Set the use of location as you see fit.
Welcome to the Wyze User Community Forum @shp2qs7qdh!
The Wyze App runs in the background on your phone 24\7. This is the only way it can actively keep you logged in and get notifications and alerts from the server. Rules that use location based triggers “watch” your location thru the app using the phone’s GPS location chip and will trigger when you have entered or left your preset “geofencing” perimiter. If you disable the apps ability to utilize the GPS location from the phone, you loose the ability to trigger the rule.
Yes
No idea how they use that, if they store and use it at all.
Don’t use Location based rules
Can’t help there. I don’t use it.
