Hi,
thanks for the quick reply, The location permission was on “while using the app” and I have now changed it to “Always”, so I will check if it solve the issue.
Attached you can see the rule
The rule configuration looks like it should work. Do you leave the Wyze app running on the phone when you leave? It’s been a while since I set mine up…can’t remember if you need to specify which device is used for location. Also, do you have a second device running the Wyze app? If so, make sure to set the secondary to allow location only when using the app and then make sure the app is NOT running on the secondary device when you leave.
This is one of my location rules which is working:
