Hi there,
I’ve emailed support already but hoping that someone can also assist me here as well.
I would like to buy a Wyze Lamp Socket + Wyze Cam v3 and I can see that the Wyze Lamp Socket standalone ($10.99) is sold out:
I can also see that there’s a bundle option that includes the Wyze Cam v3, for $48.99. My first question is, when will the standalone be back in stock? Clearly, it’s in stock if you go with the $48.99 bundle, which is literally just a combination of 2 separate products - so technically it’s not like there’s absolutely no stock left for Wyze Lamp Socket, right?
More importantly, why is the bundle more expensive? You can buy Wyze Lamp Socket and Wyze Cam V3 as standalones for $40.99 ($10.99 + $29.99). So why is the bundle charging $8 more???
Furthermore, I understand that I need to keep the switch for my outdoor lights on, so that there is power provided to the Wyze Cam v3. However, I don’t want my outdoor light to be on 24/7. I understand you can set a schedule for it to be turned on/off, but I don’t want that either. I literally just want to manually turn on/off my outdoor light, just like normal. Can this only be done via the Wyze app?
Lastly, would leaving my outdoor light switch switched on 24/7 drain power? If I’m not using my light bulb, then the power draw should only just be from the Wyze Cam, correct? I’m just worried that by having the switch on the whole time, that it’s somehow going to increase my power usage and increase my electricity bill.
