Problem setting up cameras in Google home
When I add the Wyze Home app to my Google home I see all four of my my Wyze V2 cameras. ( Yes firmware is up to date). When I tell the assistant to show me a camera is says that it appears that is not set up yet and I can do that in Google home. Any body have any suggestions.
After connecting your Wyze account to your Google Home account, you need to open your Google Home app. In the app, if you scroll down to the bottom, there should be a list of your four cameras that aren’t assigned to a home or room. Tap one and it’ll walk you through adding it to your Home and then a room in your home. Once that’s done you should be good to go.
If that’s already been done, try reconnecting your Wyze account to Google Home to refresh the connection.
This support article details how to do it. This is actually true for integrating any other company’s products with Google Home. :slight_smile:
Basically, do this :joy:
