There should be some way to set the lights at a certain incandescent equivalent wattage and color temps within the app as presets across the board. I’ve manually created “scenes” in one lighting group, but if I create a new group, it doesn’t have the same settings in there, so I have to custom create them all over again.
Additionally, the ability to manually enter the color temp, color, or power intensity would be really helpful, with the 16Million colors, it’s hard to specify the color.
Examples would be a Warm White 2700k at 60W or say Bright White at 3000k and 75W.
Yes. I would like to set hex codes for colors. Watts might be nice. Currently I equate 100٪ power to 100watts. (Not verified to be true.)
I currently use voice commands to set my default theater lights to 25% brightness at 2700 Kelvin.
If I want to clean and vacuum the room, I set 100% brightness at 6500 Kelvin. If I want something outside of cool white and warm white, I can set a color by voice. For fine tuning, I would like the ability to use a hex code.
