I have multiple Wyze v2, V3, V4 cameras, the power adapter seems to be going out after 10+ months of continuous usage. not sure if it is a quality issue, cameras shows offline. anyone else have similar issues? I have other brand cameras that are connected 24/7 for more than 7-8 years and still functional, while this is gone in less than a year.
I’m still using all my original power adapters (9 of them) after 2 years. Are yours exposed to heat or moisture? Power quality can also have an impact.
Luckily USB power supplies are cheap so easy enough to replace them as needed.
My oldest v3 power brick is indoors and working great at 3.5 years.
Are you sure your power brick is failing and not the cord or camera?
yes, Initially i thought it was a wifi issue, reset the camera set up again and connected with the power adapter, it was not working. I changed it to one of the other 5 volt adapter i have for the wireless charger, it works. I do too have adapters that works for years of continuous use, this is the first time i am facing on a camera failing on power adapter.
