Greetings,
I live in apartments, and I have zero experience with furnaces. At some point, I was sure I had an electric furnace since there’s a heat pump installed. When I was about to replace my existing Honeywell thermostat with Wyze, I noticed that Honeywell has 3 pins to select, options: “HG/HE” and it’s selected to HG. Then I found a Honeywell manual; it’s written the following for the HG option: “Leave the jumper in this position for gas or oil heating systems. In this position, the heating system controls the fan operation. When there is a call for heat, the fan starts only when the air coming out of the vents is sufficiently warm. When there is a call for cool, the fan starts right away”. So I’m confused, will appreciate any help; attaching photos of my furnace elements
