Correct Wiring Suggestions?
Good evening! I was lucky enough to pick up a Wyze Thermostat today,
Original Thermostat - Honeywell T8132A
Furnace - Nortron 21FA15
When following the app instructions it asked about the connections on my original thermostat which was W, Y, G, R, Rc (Via gold jumper?).
It recommended that we would need the C adapter. No issues, I thought.
I come to the furnace which has G, R, W1, W2, C (W2 and C have a sleeved cable split in to 2 different colors, connecting to each of these).
We have heating, however, our Air Con doesn’t turn on or kick in, with the fan constantly running regardless of mode.
Any suggestions? I’ve tried resetting the app and playing about with the options, but no solid answers. (Pictures attached)
Original Thermostat
[SOLVED] A reddit post had a similar issue, which solved it for us too, we should follow diagrams better and actually attach the AC back in,
I’m assuming your system is now wired as follows:
