Hi all,
Trying to install thermostat, but my connections don’t match the options. Odd considering it’s a basic Honeywell. Have gas furnace and ac. Photo of original connections attached.
When I removed current thermostat there is a capped wire that is probably black, or dark blue/purple. Uncapped unconnected orange brown and white.
Connected was jumper between rh & rc, then black to w, yellow to y, and green to g.
Anyone know which I can select on the wyze setup?
Honeywell setup shows the following as the same thing: (uploaded screenshot of Honeywell installation diagram also)
R, rh, v, 4
Rc, r (odd a second single r)
W, w1, h
Y, y1, m
G, f
Thank you!
