I lost the metal pin that came with the sensor. Need to replace battery.
Alternatives?
If you lived close to me I’ve got about seven of them are eight of them I just give you a couple. But other than that I bet if you call customer service at Wyze they would send you one
@Zamboknee You probably could use a paper clip or safety pin. It should work.
I don’t think I’ve ever used the pin to change the battery, but have used it to press the reset button. To open the sensor to change the battery, I just use a knife blade in the little notch area on the edge to pop the case open.
Me too but it tells you that you can use the bigger end of the pin to pop the case open
Safety pin.
