PC connect
Is there a way to connect from a PC?
Depends… you can install a software called bluestacks that emulates the Android OS within windows and then you can proceed to install the Wyze app.
Or if you setup with the RTSP firmware, you can then use it that way with compatible software.
There is a wishlist item if you want to vote for it:
