Does anyone have ideas on how to mount/secure a Wyze Pan Cam so it’s upside down onto Stucco without ruining the cam and the stucco?
@pj02 Welcome to the community!
There are several ideas in this thread here that might help out.
This very easy. Get a camera mount from Amazon. It comes with mounting screws. Yes, you will have to drill 3 small holes into the stucco. If you decide to move the cameras go to your local hardware store and get some stucco patch compound.
