Pan V3 + Nest Hub(V2) Combo
Does anyone know when and if the Pan V3 + Nest Hub(V2) Combo will again be available? This is from todays view of items available to order.
I’d also like to know if this version of Pan Cam will work with my Cam Plus and Cam Lite subscriptions. I use SD cards for all my cameras, so the upload to the cloud is needed for at least a thumbnail or short clip of events.
Only Wyze can answer supply availability issues.
The Wyze Cam Pan V3 is Cam Plus compatible. It is NOT Cam Plus Lite compatible.
None of the new release cams: V3Pro, OG, PanV3, Floodlight Pro are Cam Plus Lite compatible. This is now a legacy subscription available only on the older cams.
Thanks for the quick response. I’ll just hope they get back in stock soon.
Since the cams are in stock, I am speculating that the out of stock issue is being caused by the unavailability of the Nest Hub.
Every bundle available with the Nest Hub (with the exception of the OG) is out of stock:
