When in pan scan mode the camera lens is angled downward. This fine for a camera mounted normally. However, when the camera is mounted on the ceiling the camera lens is angled up towards the ceiling in pan scan mode. The image can be rotated, but the camera lens angle does not change. In pan scan mode I only see the ceiling and about halfway down the walls. Is there a way to change the camera lens angle in pan scan mode?
Welcome to the forum @william.shetler.
You should be able to adjust the up and down angle of the camera based on your orientation and custom zone, then the up and down should stay where you set it and the zone scan should be the only left to right, right to left change in motion
Thanks, I found the adjustments. Advanced Settings - Motor Controls - Pan Scan Serrings.
