When I look at the live stream it tells me it has “Critical battery, please charge your camera.” But if I go to events it shows plenty of events as early as an hour ago. I have power cycled the hub a few times but nothing changes.
Ideas?
Ideas?
Curious on what your battery level is currently. It is possible that events will still trigger until the battery is fully drained. However, Live Stream will cease to function as it draws more power, potentially
I’ve seen something similar with mine. Even when the battery is really low, it still logs motion events, probably because they use less power than the livestream. Once I gave it a full charge, the livestream started working again. Might be worth plugging it in for a few hours to see if that resolves it.
