Recently, videos are 0 length and in the case where one says 5m,
it shows “Connection error
Error connecting with the cloud Try fetching and loading the event again.” which still does not work
I’ve cleared storage, data, cache, rebooted the phone, stopped the app, several times.
THe network is fine, battery just charged.
Any suggestions?
Thanks!
Since you’ve already ruled out the phone side, I’d look at the camera’s connection next. Events that show up with 0 length, or with a length but a cloud error, usually mean the clip was triggered but never finished uploading, and on the Outdoor Cam that tends to be a weak signal to the base station or router rather than the battery. For a quick test, bring the cam near the base or router, trigger a few events and see if those play. If they do, it’s placement, and if they’re still empty, power cycling the base station and checking firmware in Device Info would be my next step.
