What is the maximum distance the Outdoor Camera can be from the base station and still receive a reliable signal?
The information says 300 feet in an open field but I really really doubt that. Depends where the base is located, how many walls the signal has to go through, type of material of the walls and so on. It would also depend on you modem/router ISP and whether you have the base connected via ethernet or wi-fi. Do you have a cam? If so just set it up and take it for a walk, check the signal to the cam on your app.
