What is the max distance from camera to base station?
Welcome to the Wyze community @bobski9933!
The maximum range between the outdoor camera and Base Station varies, but in an open area with no obstructions or interference it can be up to 300 feet. If you have multiple walls, doors, and other structures between the camera and the base, then that optimal range may be less,
You can check your signal strength in the Wyze app, then go to the Base Station and check the three bars next to your Wyze Cam Outdoor.
More information here: How far apart can the Wyze Cam Outdoor and Base Station be?
